It shouldn't be a huge bottleneck, but get the R9 380 instead.
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828745
1. Might bottleneck slightly
2. Don't buy gtx960. Buy an AMD r9 380(x)
3. I suggest buying a skylake core I3. You will have a better upgrade path
I5 4470     -     Cooler Master Hyper 212 evo    -    Asus Strix GTX960    -    12Gb ram    -    Adata SP600 128Gb    -    Seagate 2Tb    -    AsRock Fatal1ty B85 Killer    -    Seasonic M12II EVO 520
IN WIN 703    -     Dell P2414H    -    LG Flatron M197WDP    -    CMSTORM Quickfire XT with MX blue's    -    Logitech  G502
Quote
"To finish first, you first have to finish"
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828750
1. in some games, yes.
2. yup
3. that is more expensive, though if OP has the budget it would be a way better option
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828770
1 minute ago, IT'S JUST A GAME BRO said:
So u say slightly so upgrading GPU's or SLI isn't worth in the future?
budget?
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828784
7 minutes ago, IT'S JUST A GAME BRO said:
650$ without shipping.
why dont you get an i5, 970 8gb of ram etc
Elemental
Laptops
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828817
Because that will be out of my budget... I am building a PC not upgrading... I have to get a PSU, Motherboard, RAM, etc.
ill build a partslist
Elemental
Laptops
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828823
PCPartPicker part list: http://pcpartpicker.com/p/XgWCm8
Price breakdown by merchant: http://pcpartpicker.com/p/XgWCm8/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard  ($67.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($36.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: PowerColor Radeon R9 380X 4GB PCS+ Myst. Edition Video Card  ($199.99 @ Newegg)
Case: NZXT Source 210 (White) ATX Mid Tower Case  ($38.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($39.99 @ NCIX US)
Total: $626.42
Generated by PCPartPicker 2016-05-31 11:45 EDT-0400
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828828
Total: $626.42
Ye most of this is from Newegg and sites that don't ship to Belgium.
But thanks for searching.
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828844
Elemental
Laptops
https://linustechtips.com/topic/604099-building-a-pc/#findComment-7828847
