Hello LinusTechTips community,
Today I call upon you all in my quest to help find a solid 850W power supply / a PSU with 2x 8pin CPU power connectors for my dual Xeon X5550 server. I keep experiencing random shutoffs and I'm assuming it has to do with my current setup which is splitting the 8 pin power from a single EVGA 650W 80+ Bronze PSU into two 8pin CPU power connectors which is drawing too much power. The cooling is excellent and I can't seem to find any other issues or possible points of failure.
I'd LOVE to get a redundant PSU that can fit into a standard ATX mounting bracket or just a really solid PSU, my budget is 60 bucks and under and I don't mind (and actually prefer) buying off Ebay.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/603671-help-finding-850w-psu/
60 bucks...? That's not gonna get you a solid 850W unit. Also, 650W is plenty to power two CPUs so I'm not exactly sure why your system is shutting off.
https://linustechtips.com/topic/603671-help-finding-850w-psu/#findComment-7825039
