I'm using Z97 anniversary motherboard, and just wondering if there is any way to control speed of those 3pin and 4pin connectors without turning off my PC and going into BIOS.
So I would like to change speed of fans and pump in real time if that's even possible with my cheap mobo.
Any advice?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/603011-fanpump-control/
Any advice?
The headers on the motherboard are controlled through the BIOS once they are setup or configured you don't need to always go into there, Asrock also may have their own fan control software or using something like Speed fan is another option.
https://linustechtips.com/topic/603011-fanpump-control/#findComment-7820037
