Best PC-Case 4 Watercooling
Go to solution Solved by Senzelian,
The FractalDesign Define S is probably still the best case for watercooling.
It was specificly designed for it - so it has a lot of mounts for water pumps and reservoirs and it's pretty cheap.
Planing to make a watercooled PC
I am planing to make a watercooled PC with EK-waterblocks and hardpiping.
But what case is best for mounting reservoirs and pumps?
PS.: Live in Norway. Importing shit is expensive... So I am only going to buy mainstreem brands like CoolerMaster, Corsair and NZXT
https://linustechtips.com/topic/601957-best-pc-case-4-watercooling/
THX m8. It's perfect!
