Hello
 I have a problem my pc. I built a custom gaming PC about 2 months ago, and I have a problem that seems to only get worse. Most of the games I installed dont run at 60fps, regardless of the graphical settings. But the problem isnt constant. Sometimes games run a constant 60fps @ 1080p, but sometimes, the same game will run at 20-30 fps. I have encountered this problem with The Witcher 3, Warface, Diablo 3, Dying Light and the most recent is Doom. I've got all the drivers updated but that doesnt appear to be the problem.
My config is:
i5 4690@3.5Ghz;
 ASUS GeForce® GTX 970 OC STRIX, 4GB GDDR5, 256-bit;
8 GB HyperX Savage DDR3 1600Mhz CL9 1.5V;
ASUS B85M-GAMER Motherboard;
HDD Seagate Surveillance 1TB, 5900rpm, 64MB cache, SATA III;
Corsair CS550M 80 PLUS® Gold CP-9020076-EU, 550W, ATX 2.3;
Deepcool Maelstrom 120T watercooler;
I am running Windows 10, and I'm considering reverting to WIn 7 or Win 8.1
Any help is greatly apreciated
https://linustechtips.com/topic/601899-help-low-fps-in-most-games/
use DDU and install 361.75 - the newer drivers are crap
4 minutes ago, synnapt said:
oh and surveillance drives arnt optimeced for games use a WD blue 7200 rpm instead
The drive won't affect the FPS, only loading times.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
1 minute ago, synnapt said:
hawe u ever tried to play a game when ur HDD is under load its efecting mutch more than load time
it doesn't
Unless you have a broken drive or a drive from the 90s, you aren't going to have issues.
Just now, iHater said:
Another issue that I noticed is that whenever i start Windows the Asus GPU Tweak starts but it usually is not responding as soon as it starts up. Dont know if that is a big issue.
Remove that thing - it's crap
1 minute ago, iHater said:
I'll remove it. But does the fact that i run windows 10 affect my performance? Should i try Win 8.1 or just go back to Win 7?
Try the driver I mentioned - the current ones are utterly broken
Ok. I'll use DDU and use the drivers you recommended and see if i see an improvement.
The most obvious drop in framer rate i've been having is in Doom. I open the game, the intro are laggy as hell, but once i get in the main menu it runs the game in 60-140 fps. But sometimes when i start the game the introsrun smooth, but ingame i'm stuck between 20-30fps. I tried running it in fullscreen, borderless and there are slight differences of 2-3fps max.
56 minutes ago, don_svetlio said:
it doesn't
it actually does. the cases are rare. but your drive being under load will affect certain games dramatically.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
1 hour ago, iHater said:
Hello
My config is:
i5 4690@3.5Ghz;
device manager, check displays and disable the gtx 970 re enable
