Hi,
First time building a PC from scratch. I have everything down just need to know what PSU I should be getting.
I was thinking of going with a 850W PSU for the following:
I7-6700K OCed to 4.8 GHZ
Asus VIII Hero mobo
850 W Corsair (I) or 1000W
DDR 4 Corsair 3200 MHZ RAM (OCed as high as I can)
2 X 1080 TIs in the future (assuming they are 250W like the 980 TIs some people tell me aftermarket cards have higher wattage requirements). Until then, I will likely grab a 1080 or a 980 TI SLI (but I do not want to have to change my PSU later so I want to buy for everything now). I will be SLIing the GPUs
A half dozen Hard Drives (1 M2, 2 HDD, 3 SSD).
A 100i or 110i Corsair CPU liquid cooler.
A decent number of 140 mm fans to fill up my Corsair 760 T Case.
Thanks!
https://linustechtips.com/topic/601673-need-help-finding-psu/
1 minute ago, fixitnow said:
Just go for the biggest wattage you can afford, then it gives you room for adding more hardware later.
nah, because if I had a pc that needed under 300 watt, and I was rich, you basically told me to get like a nuclear generator or power plant in my house
Well, now you're reading this, I might as well inspire you with a deep quote
If you fall, I'll be there
             - Floor
so inspiring, so deep, the feels ;-;  THE FEELS ;-;
Newer Build which I'm gonna buy when I haz moneyz
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£0.00)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  (£25.98 @ Novatech)
Motherboard: MSI B85-G43 GAMING ATX LGA1150 Motherboard  (£78.10 @ Amazon UK)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£0.00)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£29.76 @ Ebuyer)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£0.00)
Video Card: MSI Radeon R9 380 4GB Video Card  (£179.99 @ Amazon UK)
Case: Corsair 780T ATX Full Tower Case  (£149.99 @ Amazon UK)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£70.97 @ Amazon UK)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For £0.00)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£59.00 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£24.99 @ Amazon UK)
Keyboard: Corsair K95 RGB Wired Gaming Keyboard  (£184.99 @ Amazon UK)
Total: £803.77
somethings says '£0.00' because I already bought them
probably best remix out there
If I follow you, consider your self lucky, I rarely follow people and when I do it's either because
1) I look up to you
2)I like your picture
3) Or you have an epic ass rig (40 titan x's 9 6700k's clocked at 29GHz that is what I call a epic ass rig, but no one has that soo...)
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7804522
7 minutes ago, Heewon said:
Hi!
http://pcpartpicker.com/part/seasonic-power-supply-ss850am
http://pcpartpicker.com/part/corsair-power-supply-ax860i
http://pcpartpicker.com/part/evga-power-supply-220p20850x1
These'll all provide great power to your system and their prices range from 100 to 200 $.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7804548
1 minute ago, Heewon said:
Are you sure it is enough for overclocking? I thought it would be more like 850 or 1000W
I believe it should suffice given that I have used 500w for an oc'd i7, oc'd 380, Intel 520, 850evo and 5 hard drives.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7804554
Especially with SLI?
Yeah, 750W will run your system (a 6700K and 2 1080 Tis in SLI won't pull more than 650 W out of the wall, but you don't want your power supply to be 100% loaded, so 750 is fine).
Computer Specs:
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7804562
That is incredible. I thought Overclocking eats up power like crazy.
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7804585
It does, compared to stock power consumption. The i7 consumes 100W when not overclocked but can pull as much as 200W if you push the voltage.
Computer Specs:
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7804594
id say corsair RM1000i psu. i see them for around $150 and they are tier 1 psu according to the toms hardware PSU tier list
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7804597
3 hours ago, Heewon said:
Hi,
Asus VIII Hero mobo
Thanks!
The 1080ti does not exist yet, if it ever will. We do not know how much power it will need and therefor you should not plan to buy them quite yet. 1000W will almost certainly be way more than enough for them but, again, we don't know yet. The 1080 uses more power than a 980 if I recall correctly so the ti, if there ever is such a thing, will probably be a bit on the hungry side.
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7805442
Leaked info suggests that the TDP for at least the founders edition (perhaps not the aftermarket cards) will be about 250 W TDP like the 980 TI, I'm pretty confident on this so I am going with it. 1080 uses about 180 W TDP. Do you think that I need 1000W?
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7806122
There's no leaked info on the 1080ti. If you're finding any "leaks" then you're finding false information thrown around the internet. Also, TDP =/= power consumption.
850W is plenty for two 980tis but who knows if I'll be recommending a 1000W PSU for two 1080tis in December or so?
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7806136
9 minutes ago, Heewon said:
Thanks. Is it plenty for OC as well?
850W? Yeah, assuming the GTX 1080Ti is similar to the GTX 980Ti in terms of power consumption, it'll be more than enough.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7806177
Even if I overclocked my CPU, RAM, and SLIed GPUs?
I've never seen a benchmark showcasing a 980Ti SLI setup consuming more than 650W. So yeah, you're well within the safe zone.
https://linustechtips.com/topic/601673-need-help-finding-psu/#findComment-7806186
