MACHINE_CHECK_EXCEPTION
Go to solution Solved by T0MMEN,
The answer was my PSU, i had a 6yr old 500w psu and bought a 750w PSU. Seems like the PSU couldnt run the 1.36v overclock :) The answer was my PSU, i had a 6yr old 500w psu and bought a 750w PSU. Seems like the PSU couldnt run the 1.36v overclock :)
My rig : Intel i5 4690K @ 4.6ghz w/ 1.364v cooled by 120m coolermaster seidon push/pull.
             Nvidia GTX 960 asus strix
             Silverstone 500W PSU
             Kingston fury 1600mhz
             Asus z97-p
i get MACHINE_CHECK_EXCEPTION when i play gta v and sometimes just randomly. Do you guys have any suggestions ?
i5-13600kf, 16gb Corsair 3600mhz, Asrock z690 ac itx,  RTX 3080 , 1TB+1TB PREDATOR + Western digital NVME, InWin A1, Thermalright peerless assasin 120SE
https://linustechtips.com/topic/600396-machine_check_exception/
https://en.m.wikipedia.org/wiki/Machine-check_exception
hardware issue. Usually means overheating, a broken part, CPU error, or something of the nature. Read the wiki article.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7790634
Overclock is unstable.
Remove it, and play for a while. If you get the error again.. some bit of hardware probably died, we'll cross that bridge if we come to it
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7790635
probably psu  or mobo related from all I've seen from google searches
it's related to hardware, so could be an overheating CPU, overloaded PSU, badly fitted parts, etc.
probably your OC tbh
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7790641
will try that.
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7790642
Well, i completed the mission that i couldnt cuz the pc crashed, how do i get a more stabel overclock ? I dont think its overheating cuz when i run stresstestes for about 15min it never goes above 80*C. And i've had this exact same clock for like 6months and then now its starts acting funky ? more voltage to the cpu or what do you suggest ?
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7790738
The PSU could be the issue, its about 5-6years old. I've had this clock and voltage for about 6moths and now its starts acting funky.
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7790741
probably the PSU
do you have another system to test it with?
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7790742
5 minutes ago, shadowbyte said:
probably the PSU
No, i dont trust the other PSU on my old computer :D
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7790759
https://linustechtips.com/topic/600396-machine_check_exception/#findComment-7831175
