Water cooling videocards.....
Go to solution Solved by warmmilk,
I don't think its a waste of time to buy a custom PCB card if you're gonna watercool.  Lots of the high end cards have binned GPU's, they have better power delivery.  If you plan not to OC your watercooled card then it doesn't matter.  But if you're gonna OC then I think its worth buying a custom PCB card.  Just make sure someone makes a waterblock for the card you want to buy before you buy it.  As far as I know, EK are the only guys that make waterblocks for non ref cards...  well and Swiftech, but only for the EVGA Classified, and I'm not sure if you can buy it separately...
When water cooling a video card, is there any difference between buying a reference card and a after market card with same 'layout' pcb. Usually after market cards with better coolers cost about $50 dollars more. But since we are water cooling, that is a mute point. Is the parts on the card (ie: power delivery, memory) help to OC the card better?
Thanks,
https://linustechtips.com/topic/60023-water-cooling-videocards/
A reference card refers to the PCB, not the cooler. If the cooler is reference it will be a reference card with a reference cooler. Most blocks don't support custom PCBs so buy one with a reference PCB.
https://linustechtips.com/topic/60023-water-cooling-videocards/#findComment-814760
The MSI lightning cards are SUPPOSED to over-clock amazingly, but if you're going to watercool just get the reference, no point spending the extra money. Even though, waterblock manufactures usually put out blocks for the big name aftermarket makers.
https://linustechtips.com/topic/60023-water-cooling-videocards/#findComment-814761
That what Samdb said or you can buy any MSI lightning card and buy a waterblock for them. (also some of ASUS cards have Waterblocks to buy)
https://linustechtips.com/topic/60023-water-cooling-videocards/#findComment-814780
if you want good power delivery and stuff i would go with the asus cards (like @M-ursu) said becus ek makes water blocks for some of them
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
https://linustechtips.com/topic/60023-water-cooling-videocards/#findComment-814921
Thanks,
This is another option.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130923
https://linustechtips.com/topic/60023-water-cooling-videocards/#findComment-815098
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
https://linustechtips.com/topic/60023-water-cooling-videocards/#findComment-815582
there are very few manufacturers of non-reference PCB GPUs. and they'll only be
the elite cards if that. and usually at a premium price, due to the low volume being
sold.
research your GPU choice with all manufacturers for a water block. if not made,
move to the next choice, etc.. way too many members have purchased non-reference
cards with the fun news to find they don't have an option for water cooling because of
a lack of water blocks.
airdeano
https://linustechtips.com/topic/60023-water-cooling-videocards/#findComment-815764
Intel 3570k @ 4.4 GHz |Asus Sabertooth Z77 |EVGA GTX 660 Ti FTW |Kingston HyperX Beast 16 Gb DDR3 1866 (2x8Gb)
|Samsung 840 250 GB |Western Digital Green 2TB 2x |Cooler Master 850w 80+ Gold |Custom Water Cooling Loop |Noctua NF-F12 4x
|Noctua NF-A14 3x |Corsair Carbide 500R (White) |Corsair K95 |Razer Mamba |Razer Megalodon |Samsung SyncMaster T220 2x Computer Bucket List   Greatest Thread Ever   WAN Show Drinking Game  GPU Buyers Guide
https://linustechtips.com/topic/60023-water-cooling-videocards/#findComment-816671
