Hey Guys im new to the whole thing but i been doing a bit of research and this is what i came up with. Can you guys please let me know if this is a good gaming/ productivity build. If not please let me know where i went wrong, or what is a better sub. Please and thank you. P.S new to the forums as well.
Case: Corsair 780t
CPU: Intel I7 6700k
CPU Cooler: Corsair H100i
Motherboard: Z170 Hero Alpha
RAM: 32GB Corsair LPX
Storage: Two Intel 730 480GB
Video Card: MSI Geforcearrow-10x10.png GTX 980TI
Power Supply: SeaSonic 750W 80+ Goldarrow-10x10.png
https://linustechtips.com/topic/599745-please-help/
Why not wait for the 1080 in the 27th of may? It's faster than the 980Ti and will be cheaper. Also do you really need 32GB?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/599745-please-help/#findComment-7783634
If you're looking at buying a whole system soon, then I'd advise waiting for the GTX 1080.
The parts you have chosen are good, but some are more expensive than they need to be. The board can have a fair bit of money saved on, and going for a single 1TB SSD will likely be cheaper than two (1TB 850 EVO is what I'd go for). Do you need 32GB of RAM?
https://linustechtips.com/topic/599745-please-help/#findComment-7783638
1 minute ago, Oshino Shinobu said:
If you're looking atarrow-10x10.png buyingarrow-10x10.png a whole system soon, then I'd advise waiting for the GTX 1080 if you have the budget for it.
The parts you have chosen are good, but some are morearrow-10x10.png expensive than they need to be. The board can have a fair bit of money savedarrow-10x10.png on, and going for a singlearrow-10x10.png 1TB SSD will likely be cheaper than two (1TB 850 EVO is what I'd go for). Do you need 32GB of RAM?
I wont be buying until a month or 2, but is 32 gb overkill? i want something reliable and to have enough potential for big games on high or ultra resolution
https://linustechtips.com/topic/599745-please-help/#findComment-7783655
For any game, 32GB is overkill. 16GB is the most you even remotely need for games right now, and even then, it's overkill in most cases.
However, you mentioned productivity, so more RAM could be beneficial to you, depending on what programs you work with. I would advise starting with 16GB in a 2x8GB configuration, then add another 16GB if you need more.
https://linustechtips.com/topic/599745-please-help/#findComment-7783665
12 minutes ago, theanimun said:
Only if you wish to play batman: arkham knight
You really shouldn't be playing it in the first place on PC!
https://linustechtips.com/topic/599745-please-help/#findComment-7783678
3 minutes ago, Oshino Shinobu said:
For any game, 32GB is overkill. 16GB is the most you even remotely need for gamesarrow-10x10.png right nowarrow-10x10.png, and even then, it's overkill in most cases.
However, you mentioned productivityarrow-10x10.png, so morearrow-10x10.png RAM could be beneficial to you, depending on what programsarrow-10x10.png you work with. I would advise startingarrow-10x10.png with 16GB in a 2x8GB configuration, then add another 16GB if you need morearrow-10x10.png
Got it, so everything is all good just change to 16gb, wait for GTX1080, and get 1TB 850 EVO instead of the 2 480GB. What about the motherboard? can that stay or it really dosent matter? Build theme is black and red if that matters lol
https://linustechtips.com/topic/599745-please-help/#findComment-7783682
The board is just expensive for what it is. That's true for pretty much all of the Asus ROG boards.
Have a look at the MSI Z170A Gaming M5 and MSI Z170A Gaming Pro Carbon.
https://linustechtips.com/topic/599745-please-help/#findComment-7783700
Have a look at the MSI Z170A Gamingarrow-10x10.png M5 and MSI Z170A Gaming Pro Carbon.
Got it, Thanks for the help bud my problem is solved i was just so lost at first. one more thing on the GTX 1080 is it the GeForce you where talking about?
https://linustechtips.com/topic/599745-please-help/#findComment-7783729
It is part of the GeForce series. There's only one GTX 1080 (in term of actual GPU, there will be various coolers for it)
https://linustechtips.com/topic/599745-please-help/#findComment-7783736
Thread moved to New Builds and Planning.
https://linustechtips.com/topic/599745-please-help/#findComment-7783740
