card stuck to my motherboard??
my geforce 8400gs has died. and i'm trying to take it out but somehow its stuck to my motherboard. one side will come out a bit but the other stays right there. i've tried taking out the back cover and pushing the metal thingy but nope.
did you release the pcie lock?
dont pull it too roughly or the entire pcie cover will come out, then you have a big problem
-sigh- feeling like I'm being too negative lately
Did you push in the slot button to release the card from the physical slot?
yes i did. anyways the side that's stuck is the one nearer to the back of the case, so it's not a lock problem
what's the slot button?
There should be a lever looking thing on the right side of the slot.
10 minutes ago, Pesukarhu said:
Have you tried wiggling it? Also screwdriver with extreme care.
yes i have.
Edited by Godlygamer23
Put GIF in spoiler.
the pci lock? yes i have and the side which is stuck is the one nearer to the back of the case, so it's not a lock problem.
then make sure you unscrewed the gpu and that the IO (namely VGA or DVI) ports arent caught on the case
then you can maybe pry at the place where you screw the card in, making sure the plastic of the pcie lane below doesnt follow
gpu is unscrewed and i tried pulling the io so hard it got bended ._.
Put GIF in spoiler.
io? im talking about the pcie bracket
it's fine of that bends a bit, you can bend it back, it's just a piece of metal
i've already pulled on that. the bracket is shit anywaysand it won't even hold it when the card is placed so the bracket isn't what is causing the problem.
can we has pics of the situation?
can we get a picture?
unscrew the card from the case?
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
you shall has pics of it
i'm on it
make sure that you pressed the gpu lock down fully...these things can be stubborn and more then once I didnt realize it wasn't fully down when I was a noobie with a comp internals. The lock should have resistance then suddenly get "loose" when you get past a certain point. at that point its unlocked. Cause ya...what you are describing sounds ALOT like what I was feeling when I 1st started messing with my gfx card.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
the part which is stuck is the one further away from the lock.
1 minute ago, DXMember said:
once again - unscrew the PCI-E from the case and release the PCI-E lock
i know, i've already tried unscrewing, i'm not stupid. and the pci lock is removed.
Your pictures are misleading then. You're showing us something you've apparently already done.
