Case Fan Direction
Read this bud it will help you out...So I have the antec three hundred two, and its a good case. I also have all the case fan slots filled except for the one behind the motherboard. I'm just wondering if I have all the fans in the best possible spots for cooling, and if I have them blowing the most effective direction.The 140mm on the top blows out, the 120mm on the back/top blows out. The two 120mm's on the front bottom blow in. The 120 on the left near the bottom also blows in (towards the motherboard) and the final slot behind the motherboard is empty. Are these all optimal directions for the fans to be going in? Would it be more effective if for example I took one of my fans off the front and stuck it as an exhaust behind the motherboard? By looking at Antec's website I have them all blowing in the suggested direction but I'm wondering if maybe switching them around a bit would improve cooling or get rid of dust build up etc.
Pics of the case for anyone interested: http://store.antec.com/Product/enclosure-gear_for_gamers/THREE-HUNDRED-TWO/0-761345-15320-1.aspx
http://www.overclock.net/t/1394467/daves-el-cheapo-heatsinks-air-cooling-guide
