power supply help
Solved by threadysparrow,
anything over 600W is fine if you have less than 3 video cards. If you start SLIing and Crossfiring them together like christmas lights, then you might want to look into a 750W.
Watts are not the only thing to consider. You have to consider connectors. Your new video card will require 2 PCIe power connectors (6 or 8 pin) and if you do not have those then you need to find a different power supply.
