Hi y'all. I wanted to transfer a windows os from a 1tb WD green to a 640gb WD Black. I used XXCLONE but although it boots into the windows 8 lockscreen when I log in there's just a black screen and a mouse cursor.
Does anyone know how this can be done without loosing any data?
https://linustechtips.com/topic/5995-hard-drive-cloning/
So you're installing a new boot drive? If so, just intall windows onto that and then instal the original drive and copy what you need.
I don't want to copy what I need. I need everything. I need an exact clone of the WD Green to the WD Black...
https://linustechtips.com/topic/5995-hard-drive-cloning/#findComment-66619
Long time fan of Acronis here as well - usually works with no hassle...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/5995-hard-drive-cloning/#findComment-66899
Yeah, I can vouch for Acronis, used it quite a few times, hasn't failed on me before.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/5995-hard-drive-cloning/#findComment-67217
