5 minutes ago, Sans said:
might as well go for a 1440p monitor if you want the ultrawide for realestate.
https://linustechtips.com/topic/599351-help-me/#findComment-7779749
no. ultrawides are awesome.
7 minutes ago, Sans said:
what gpu do you have?
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/599351-help-me/#findComment-7779757
I just want someting that will work perfectly with a 1070.
Ok maybe something over 700 then
4 minutes ago, josephaltareb said:
k thats more like it.
LG 34UM94-P
2 minutes ago, josephaltareb said:
for 500 you get a short ass 1080 ultrawide which looks kind of awful.
a 1070 is not powerful enough to game at that resolution. 29" 2560*1080 is enough im using it since 2 years.
i would recommend to get an amd gpu like the 390 or polaris and go for the 29UM68-P. it has freesync from 40-75hz meaning you will have higher refresh rates and a overall smoother experience than any other monitor. pixel density is over 100dpi and your saving a lot of money.
https://linustechtips.com/topic/599351-help-me/#findComment-7779806
woah woah woah  stahp right there.
a 1070 is better than the 970
970 = 60fps (lower the AA rating and other filters) 1440p
1070 = // but a bit better.
I DON' KNOW!?!?!? xD I can buy another 970 and then i can sli or buy the 1070 and ignore the 970 WHAT SHOULD I DO!?!?! lol
https://linustechtips.com/topic/599351-help-me/#findComment-7779830
6 minutes ago, josephaltareb said:
woah woah woah  stahp right there. @ChrisCross
you realize that 3440*1440 is nearly as hard to drive as 4k? even the gtx 1080 cant do that properly!
https://linustechtips.com/topic/599351-help-me/#findComment-7779842
the 1070 is better than the 970, so get a 1070!
we dont have benchmarks of the 1070 yet! we can assume its going to be a bit quicker but we dont know yet.
https://linustechtips.com/topic/599351-help-me/#findComment-7779847
you realized that i said lower filters! Damn, read what i just said
@Sans are you ok with putting the settings a little lower than usual?
a game at higher resolution but with low settings will look worse than normal resolution with ultra settings. and even with low settings your going to have trouble at that resolution!
also the freesync monitor has a higher refresh rate and no tearing.
https://linustechtips.com/topic/599351-help-me/#findComment-7779867
did i say LOWEST or A LITTLE LOWER?
wtf aperently you cannot read.
a 1070 just wont be able to do it! its a really great display but if you dont have a gpu to match it its pointless.
https://linustechtips.com/topic/599351-help-me/#findComment-7779888
wtf? we dont know that at all! do you really believe the nvidia charts :D
and he has that display for video editing, not for gaming!
https://linustechtips.com/topic/599351-help-me/#findComment-7779907
aaaaaaaaaaaactually he games on that too.
AAAAAAAAAAAAAAND we do know that the 1080 is 20% better than the titan x
so if the 1070 is 20% worse than the 1080, the 1070=titan x
SOOOOOOOOOOOOO yes you can play 4k with a 1070.
https://linustechtips.com/topic/599351-help-me/#findComment-7779915
LG 29UC88
 Don;t get 2560x1080 with 34 inches, too low ppi.
CPU: i7-6900K 4.5 GHz | Motherboard: X99 Sabertooth | GPU: RTX 2080 Ti SLi | RAM: 32GB DDR4-3400 CL13 | SSD: SX8200 PRO 512GB | PSU: Corsair AX1600i | Case: InWin 805C | Monitor: LG 38UC99-W 85Hz | Keyboard: Wooting One Analog | Keypad: Azeron Compact Analog | Mouse: Swiftpoint Z | Audio: Klipsch Reference 5.1
https://linustechtips.com/topic/599351-help-me/#findComment-7779934
calm down. you cant play 4k with a 1080 at max settings!
just look at this, its under 60fps in nearly every game.
https://linustechtips.com/topic/599351-help-me/#findComment-7779945
