So i killed my hard drive by connecting a 7 volt wire into a 12 volt header for a molex to 4 pin gpu fan adapter for a aftermarket gpu cooler, this created a lot of smoke and i quickly turned my pc off at the wall during boot. Windows wasn't located on that drive but the drive is still dead from the over voltage. My question is whether the information on the platters will have been damaged or just the circuit board has been killed.
CPU: Intel I5 4690K | GPU: Asus R9 280x | PSU: Evga 600w | RAM:8GB DDR3 | HDD: WD 1TB | HDD: WD 500GB | SSD: Sandisk 120GB
https://linustechtips.com/topic/598867-dead-drive-recovery/
is this a hard drive, or an ssd?
If it's the SSD in your sig then you're out of luck.
If it's the HDD you've either fried the motor or the circuit board.
Check the circuit board for any burn marks - if its burnt - check online (e.g eBay) for the circuit board for your specific drive model & firmware, or you may need to get a whole second working drive to salvage it from.
If the board looks alright, then you may be in for a hard time as it could be the motor. The problem with modern large capacity drives, is that they have multiple platters, and you cannot move the platters out of alignment or they can't be read. So you can get a second drive of the same model, but you have to transplant the motor & head from the working drive into your drive - as if you unbolt your drives platters, you will not be able to align them again and any existing data will be destroyed.
Generally its best to take it to a recovery centre, so they can do this - as they have the necessary tools that *should* be used for moving the head - otherwise you risk damage to one of the platters.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/598867-dead-drive-recovery/#findComment-7780399
Ok i will have a look at the board later to see if it looks ok or not and yes it is a dead hard drive
https://linustechtips.com/topic/598867-dead-drive-recovery/#findComment-7788352
Is this the circuit board for the hard drive(not my picture)
https://linustechtips.com/topic/598867-dead-drive-recovery/#findComment-7799007
On 20.05.2016 г. at 11:11 PM, Jack Kaye Pc Gamer said:
~snip~
Hello :)
I'm sorry for the situation you are in. :/
Such situations don't always damage the data on the drive beyond repair but for the best chances of getting it back I'd contact a data recovery company as the guys there have the tools to extract the data off the platters directly.
If the problem turns out to be just the PCB you may be able to find the exact same drive from the exact same batch and swap the PCBs and thus run the drive but this is very risky, not supported and has a high chance of being unsuccessful.
@Jarsky gave you some excellent advice so I'd follow that too.
What are the brand and the model of the drive?
Post back with some progress,
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/598867-dead-drive-recovery/#findComment-7802354
6 hours ago, Captain_WD said:
Hello :)
Captain_WD.
Heres some pics of my pcb  http://imgur.com/a/ynBG5
You think its damaged
Edited by Jack Kaye Pc Gamer
Forgot to add info
https://linustechtips.com/topic/598867-dead-drive-recovery/#findComment-7804081
13 hours ago, Jack Kaye Pc Gamer said:
~snip~
I can't tell for sure from the photos, but if the drive isn't detected in BIOS, Device Manager or Disk Management you can be pretty certain that the drive is damaged. The problem might not be only with the PCB as there are other electrical parts in the drive that may have been damaged too.
Captain_WD.
https://linustechtips.com/topic/598867-dead-drive-recovery/#findComment-7807187
