3 minutes ago, CodenameScorpion said:
I would say yes, but I would recommend using project Fi, as coverage is superior, and it is hard to beat the whole "Get a credit for your next bill from the data you don't use.
could i swap out the sim card and switch networks if i wanted to?
https://linustechtips.com/topic/598559-nexus-5x-project-fi/#findComment-7771491
Project fi is extremely expensive. Anyways, in order to get the cheaper nexus price, you have to have one month of service with Google and then you can cancel it.
https://linustechtips.com/topic/598559-nexus-5x-project-fi/#findComment-7774274
Project fi is 20+10 for every gigabyte of data. Being a normal user, I need around 3gb of data which translates to 50 dollars. I pay only 44 on verizon after taxes and fees including the installment plan for my s7 for 3gb of data. Project fi is simply too expensive and the phone options are extremely limited.
Edit: alternatively, if I were to use tmobile Walmart plan, I would get 5gb of lte and unlimited Netflix, youtube, and music streaming for 30 plus the monthly cost of the s7 which although more expensive, amounts to a better value.
https://linustechtips.com/topic/598559-nexus-5x-project-fi/#findComment-7774733
so as you said earlier, i could possibly buy this phone with project fi which saves like 150$ and after a month if i find its too expensive, i could end my service and switch?
https://linustechtips.com/topic/598559-nexus-5x-project-fi/#findComment-7775445
Yes. Keep in mind that with the Fi service, you will have a new number so you're friends may have difficulty contacting you. If in the end, you do decide to switch to Fi, I recall them allowing you to port your number over, you might have to look up the details for that.
https://linustechtips.com/topic/598559-nexus-5x-project-fi/#findComment-7775601
You can use your current number on Fi.
https://linustechtips.com/topic/598559-nexus-5x-project-fi/#findComment-7780428
