PS4 speed ≠ PC speed
Solved by Droidbot,
5 minutes ago, FruitBasketSilex said:Then PSN must have some trash ass american servers if what you say is true.
WNR2000V3
I am given 60/4(8?) by my ISP, and quite frequently experience marginally above that (up to 70mbps) I'll try the wired PS4 in a moment, should be easy, because my PS4 sits about a foot and a half above my PC.
Try wired, then come back. AFAIK the PS4 has N wireless and will be capped to probably 54Mbits if it isn't close to the router
