Typical Asus quality, either really good or really bad.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/598031-review-pg279q/#findComment-7765836
8 minutes ago, ACoffeeGuy said:
If I get one and it ends up being bad is there a warranty on it to exchange for a new one?
Depends, Asus is typically pretty good about approving RMAs. However, I've had to RMA my PB258Q three times and every single one had issues. I honestly gave because they are so slow with the RMA, I had to wait a month each time. It was ridiculous. If you have Amazon Prime, I would suggest ordering from them and just keep exchanging until you get a good one.
https://linustechtips.com/topic/598031-review-pg279q/#findComment-7765927
If anything, it might be best to think of this as your second monitor that you use for gaming, rather than your workstation monitor. I'm going to take a gamble on the model, but it's not going to be my primary work one. Maybe some day, we'll find the unicorn monitor.
https://linustechtips.com/topic/598031-review-pg279q/#findComment-7768206
I don't think we are at the stage yet where there is a nicely priced VRR based monitor that has great screen qualities and is reliably built. The price of these screens is kind of high when you think about it and the variance in quality is just bad. I think we are likely to see a better convergence at 4k in a few years time where the mass of the market and companies will go with full intent and that will introduce the higher quality products into the market at reasonable prices. We are just in the middle of a storming of new technology and its going to settle on a new combined standard at some point in the near future. Buying in the middle of all that is just a bit of a mixed bag. Depends on your approach and budget in regards to computer kit and how long you hang onto it for.
https://linustechtips.com/topic/598031-review-pg279q/#findComment-7768381
Well my plan is to get a PG279Q as a gaming monitor and a secondary work monitor, since I have a Dell P2715Q already (it's a 4K IPS 60Hz monitor) and then when a proper 4K 144Hz monitor comes out I'll replace the PG279Q with that.
And hopefully from someone other than Acer or ASUS. ASUS I've had a mostly positive bag with, it works, but I feel like they cut corners in places. Dell has a 144Hz 1440P GSync monitor, but it's TN and well, I can't stand TN anymore. And it's $800. Otherwise I would've gone with them. And Dell scored a lot of points when I saw it for presentation, because I hate most "Gaming" branded stuff design wise.
https://linustechtips.com/topic/598031-review-pg279q/#findComment-7768399
