hi im looking for a new cpu cooler for my phemon x4 955be and im on 3.6ghz at stock voltage load 51-idle is33c and im trying to get 3.8ghz and i have a h60 with sp120 and its not that great so i have been looking at this PH-TC12DX will this help
amd fx 6300  @4.4ghz @1.4/ga-970a-ud3/HD78702gb /antec 620w psu
https://linustechtips.com/topic/5974-cpu-cooler/
Not sure if that TC12DX will do a lot better - that is more their middle range one. Might get a few degress better. Hard to say.
If you have the clearances though, Phanteks PH-TC14PE will give you some good temps - this is their top of the line and rates up there as one of the best.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/5974-cpu-cooler/#findComment-66461
If you want quietness for your cpu cooler, I would go with a Noctua NH-D14. But before buying this check your ram and case to see if you have enough clearance.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/5974-cpu-cooler/#findComment-67108
