I am building a really low budget Pc, after some advice from you guys and the Gtx 750Ti being discontinued I realized that a Intel graphics build was the way to go, I only need this pc for work, nothing intensive word power point ect, for games I only really play cs:go or leauge/dota. I looked into what the integrated graphics could handle and it should be able to do this fine.
I work/play on a Samsung sync master p2270 22 inch 1080 monitor, budget. I am hoping to be able to play 40fps + at around medium-low settings.
I am from Australia and the dollar is really shitty so my budget is around 400 Aud
So my questions are, is the case I am getting going to work and also is there anything else I should change to maximize performance?
[Build]http://imgur.com/Fk9fZUB)
Edit
http://au.pcpartpicker.com/p/n3zwt6
Edit 2 Different Case  Deepcool Smarter Mid Tower Case
https://linustechtips.com/topic/597100-build-help-compatibility/
Go with an AMD APU for best value/money and gaming performance
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/597100-build-help-compatibility/#findComment-7755090
I really do not know much about amd cpu's what is the mirror of a intel i3?
The two Amd cpu's I have found are the  AMD FX-6300 6 Core Black Edition ProcessorAMD A10 7860K 4-Core Processor Which one?
Edited by ShinySword
https://linustechtips.com/topic/597100-build-help-compatibility/#findComment-7755134
If it says A before the name of the chip it has inbuilt graphics, On second thoughts, getting a radeon HD 6950 secondhand for around $30 and getting maybe a http://au.pcpartpicker.com/part/amd-cpu-ad880kxbjcsbx
should give much better performance.
@rice guru
https://linustechtips.com/topic/597100-build-help-compatibility/#findComment-7755234
