So I recently upgraded my pc from a FX8350 4.0GHz, 32 GB of ram to a i7-4790k and used all the other drives I had. Hoping I didn't need to load a new version of Windows 10, again.  But now. After installing the new hardware my pc takes forever to load, I also timed it and its exactly 40 mins. Please advise guys. Thank you in advance.
https://linustechtips.com/topic/596537-need-help-with-pc/
You have to reinstall Windows
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/596537-need-help-with-pc/#findComment-7749723
When you switch computers, windows needs to be reinstalled.
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
https://linustechtips.com/topic/596537-need-help-with-pc/#findComment-7749734
13 minutes ago, tslammer99 said:
Thanks guys. Anyway to not reinstall windows?
Was it the first time you rebooted your computer? Windows 10 is pretty versatile at changing hardware but required installing them on the first boot.
Can you try rebooting again?
https://linustechtips.com/topic/596537-need-help-with-pc/#findComment-7749791
No. The Windows installation is tired to your hardware, you'd have to reactivate it anyway
My rig:
https://linustechtips.com/topic/596537-need-help-with-pc/#findComment-7749806
Hello MimigaKing,
I reinstalled windows 8.1 pro on my pc as it was the only copy I could find without buying a new copy of windows 10 pro. Now all is working but one of my VolociRapter drives isn't working or acting weird as when it is in the system, it takes close to 30 mins to load windows, but when I take the drive out (hot swap) it loads fine less than 1 minute. That drive is where I keep all my steam games. Can call me dumb by doing that works awesome when I go to lan parties as I do not need to redownload some games.
My rig:
CPU: i7 4790k @3.5ghz Max 4.0ghz COOLER: Thermaltake Water Ultimate 3.0 MOBO: MSI Z87-GD65   RAM: 16GB Dominator Platinum   GPU: XFX Radeon HD 7970x2   PSU: Corsair AX1500i   CASE: Corsair 800D HDD: WD VelociRaptor 1TB + 2xWD Black 1TB raid 0
https://linustechtips.com/topic/596537-need-help-with-pc/#findComment-7752176
After you upgraded to the 4790K, did you install the drivers that came with the new motherboard? Or better yet, the latest drivers from the motherboard's website?
In any case, it could simply be that your VelociRaptor co-incidentally crapped out at the same time. I'd replace the VR with an SSD and copy the games over while you still can.
Or, you could try using a different SATA port for the VR. Is it SATA2 or SATA3? Maybe it matters.
Now that you have Windows 8.1, you should be able to do a free upgrade to Windows 10 (if that applies to the "Pro" version.)
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/596537-need-help-with-pc/#findComment-7752223
