Hello. I've just purchased a pair of Beyerdynamic costom one pro's and am wondering if there is any point in investing in a Dac or sound card? I am running a Gigabyte Z77 UD5H with a Realtek ALC898 codec as the onboard audio on this board. I'm not keen on spending extra money if either of these choices aren't going to have notisible improvements.
https://linustechtips.com/topic/59622-beyerdynamic-sound/
nah, if you read my review which is floating around on this board somewhere you'll see how they're specifically designed for low power applications like your onboard chipset or a smartphone.
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/59622-beyerdynamic-sound/#findComment-808849
It's only a 16ohm headphone so you'll be perfectly fine.
Anything that's maybe 64ohm or higher you might wish to buy a sound card or dac that has an amp.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/59622-beyerdynamic-sound/#findComment-808929
Alright! Thanks for the replies. I'm probably not gonna throw away money on a sound card.
That's a little crude of a fashion to put it across. You think soundcards are a waste don't u
https://linustechtips.com/topic/59622-beyerdynamic-sound/#findComment-809649
You don't, but if you get a decent soundcard/DAC, you will notice a difference in the dynamic range and tonality of the sound, especially through a decent pair of cans like those. Gives a richer sound.
I certainly missed the hell out of my Motu 8Pre when I was away and had to use on board audio. Can't wait to get my BD 770 Pro's back as well! :)
https://linustechtips.com/topic/59622-beyerdynamic-sound/#findComment-831612
What did you get.
http://www.bhphotovideo.com/c/product/764102-REG/Nikon_D_5100_Digital_SLR_Camera.html
(He was referring to nice pictures)
I also plan on picking up some LCD2's if I can find a good used pair.
https://linustechtips.com/topic/59622-beyerdynamic-sound/#findComment-831633
Nice. I have some Canon one. I think it's the 1100D, can't remember.
Sponsored by Twitch and DxRacer.
https://linustechtips.com/topic/59622-beyerdynamic-sound/#findComment-831652
