Help with compatibility!!!
Go to solution Solved by TrigrH,
1 minute ago, mrHoot1 said:
ill make a repost i guess,,
just edit the thread
Hello all,
This is my first ever post on Linus' community website and i'd love to ask you guys a very simple (yet complicated) question to answer:
Will ALL these parts (as listed) be compatible?
CPU/APU: AMD A8-5600K 3.6GHz Quad-Core Processor
CPU Cooler: Noctua NH-U9S 46.4 CFM CPU Cooler
Case Fan(s):  Noctua NF-S12A FLX 120mm Fan (x2 or 3)
GPU: Asus Radeon R7 370 4GB Video Card (2-Way CrossFire)
Motherboard: Asus A88X-PLUS ATX FM2+ Motherboard
RAM: G.Skill Ripjaws X Series 14GB (4 x 4GB) DDR3-1333 Memory
Storage/HDD: Samsung 840 EVO 250GB 2.5" Solid State Drive (x2) and Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Case: Deepcool DUKASE ATX Mid Tower Case
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer
OS: Microsoft Windows 10 Home OEM (64-bit)
Parts I already have:
Operating System
    Windows 10 Home 64-bit
CPU
    AMD A8-5600K
    Trinity 32nm Technology
RAM
    8.00GB Single-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
    ASRock FM2A88M-HD+ (CPUSocket)
Graphics
    BenQ RL2455 (1920x1080@60Hz)
    2048MB ATI AMD Radeon R7 200 Series (Gigabyte)
Storage
    931GB Western Digital WDC WD10 EZEX-00BN5A0 SATA Disk Device (SATA)
    465GB Seagate ST950042 0AS USB Device (USB)
Optical Drives
    TSSTcorp CDDVDW SH-224DB ATA Device
    Alcohol V-SATA CD/DVD
Audio
    AMD High Definition Audio Device
PSU
    Some random generic shitty brand WITHOUT a PCIe power cable
p.s i already have an AMD Radeon R7 370 4gig sitting on my desk because the PSU doesnt even have a PCIe power cable >:(
Recommendations are well appreciated,
Thanks a bunch,
LJT
https://linustechtips.com/topic/596142-help-with-compatibility/
Operating System
CPU
    AMD A8-5600K
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
i forgot to say i already have an (x1) Asus Radeon R7 370 4GB Video Card on my shelf because my current power supply is dogshite and doesnt have a PCIe cable to power the R7 370, but im currently using an R7 200 Series Video Card.
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7745985
well you dont even have a PSU listed, lets have a separate list with the parts you want to install and buy. (mark the parts u already own in bold.)
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746007
19 minutes ago, mrHoot1 said:
just did anyway
Currently have:
AMD A8-5600K
8 GB Single-Channel DDR3 @ 665MHz (9-9-9-24)
2gb ATI AMD Radeon R7 200 Series (Gigabyte)
1TB Western Digital WDC WD10
Want to install:
AMD Radeon R7 370 4gb – Already own one (should i get another and crossfire?)
16gb of ram
new cpu cooler and case
SSD and new HDD
new PSU
Correct?
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746082
25 minutes ago, TrigrH said:
Currently have:
AMD A8-5600K
Want to install:
16gb of ram
SSD and new HDD
new PSU
Correct?
yes! thank you, i just couldnt think on how to lay it out is all
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746132
a new cooler wont give u more performance unless u can OC? get an 850 evo instead of an 840, idenify which 8gb ram you have by looking at the sticker on it and get another one, keep your motherboard, no point going crossfire has ur CPU will hold u back, seasonic 620w would be a good power supply.
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746140
ill make note on that, thanks, and would you have any suggestions for any better AMD CPUs? just wondering
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746152
you might as well get a new mobo and intel CPU at that point. (im not sure what ur budget is)
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746160
well, you pretty much saved me $600+ by cutting out the extra video card plus the other crap, so i couldnt care what it is as long as its compatible, if you can list me a motherboard+CPU that would be wonderful, as long as its under $600 for both of them :P
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746175
well once you do that then the CPU is not holding you back, so maybe see how what I suggested suits your needs
https://www.pccasegear.com/sc/tA5
the ram is just a placeholder till you know what u have.
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746192
just turned off the computer and took the RAM out, it turns out they're from Samsung
https://linustechtips.com/topic/596142-help-with-compatibility/#findComment-7746219
