3 minutes ago, Perismaz said:
Is it necessary to have a cooler with the same socket with the CPU?
Well if it doesn't support it, then it doesn't have the hardware designed for mounting to that socket. What socket and cooler are you looking at exactly?
https://linustechtips.com/topic/595999-cooling-sockets/#findComment-7744481
It has to be compatible with the socket of the CPU, for instance it will be like this
Quote
Supported Sockets
AM2, AM2+, AM3, AM3+, FM1, FM2, FM2+, LGA1150, LGA1151, LGA1155, LGA1156, LGA1366, LGA2011, LGA2011-3, LGA775
Source:  https://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2
Unless you're doing a ghetto mod that is, where you aren't using the hardware supplied with the heatsink.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/595999-cooling-sockets/#findComment-7744484
8 minutes ago, Perismaz said:
so not necessary cooler with 1151 socket right?
They have the same mounting hardware so it will work without any issues, just note that it was mentioned that the mounting pressure on skylae LGA 1151 is lower due to the thinner PCB material of the new CPU's.
https://linustechtips.com/topic/595999-cooling-sockets/#findComment-7744586
ohh okey thanks for your time mate
https://linustechtips.com/topic/595999-cooling-sockets/#findComment-7744602
