Unknown Problems With My Internet. Please Help
Hey guys. First off I apologize in advance both this forum and the topic of networking in general are kind of new to me but I watch LTT and figured this would be a good place to come. So this problem started quite some time ago. I have Xfinity internet and according to my most recent speedtest.net test I'm getting about 15 ping, 30.05 Mbps down, and 6.06 up. My desktop is connected via Ethernet to my router/modem (and yes, it is the one they include that has both the router and modem in the same box). Multiple times a day my connection (along with everyone else in the house) suddenly drops, and the lights on the router/modem that are usually on (including Tel1, 5Ghz. 2.4Ghz, Online, US/DS, and I believe even the power indicator) slowly turn off one by one and then back on. I have called the company multiple times, and multiple people have come out to look at the problem, which usually results in them giving us a newer modem/router. Supposedly, we now have the newest model that they send out, but this problem has occurred on all the router/modems they give us (as far as I can remember, but I could be wrong on that detail). I've talked to some of my friends who know much much more about networking than I do, but I thought coming here might be beneficial. Ask any questions you need to but please help. Thanks
CPU Intel i5-4690K, Motherboard ASRock Z97 Extreme3, Memory G.SKILL Ares Series 8GB (2x4), Storage WD Caviar Blue 1TB, GPU SAPPHIRE Vapor-X R9 280X, Case Corsair 300R Mid-Tower, PSU EVGA 600B 600W 80+ Bronze, OS Windows 10 Home 64-bit, Keyboard Corsair K70 RGB, Mouse Logitech G502, Headphones Audio Technica ATH M50X, Microphone Antlion Modmic 2.0
Did you try plugging the router into an electrical outlet on a different breaker? If even the power LED is giving out with a completely different unit I can't help but feel the issue might not be the router at all.
After having it happen again, I did not notice the power LED turning off so I believe I was wrong about that detail
Have they ever done a line or signal test when they came out? It seems like they aren't doing much to try and troubleshoot the issue other than cycle you through router/modem units in hopes that will fix the problem. Any utility work in the area recently that you know of or perhaps if you have an idea of the age on the internal coax cable that could help narrow down the issue.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
It could be an issue with the ISP side, or an issue with the wiring inside your house. Get them to run some signal tests, and see how the signal is to the nearest ISP router.  Also if you have another router available, see if it works.  Firmware issues can cause all sorts of problems, so can problems in the hardware design of it.  Most ISP routers are not fully optimized.
I've often had to get people to purchase off the shelf routers from the store instead of getting one the ISP because they just flat out perform better.  If you can't afford a good router see if you can buy a cheap one, even though they are cheap often they work fine as long as it's a good brand and has decent reviews.  TP-Link are the best in the lower cost range is what I've found personally.
But don't worry about that now, focus on getting the ISP to do their damn job and ask to speak to a professional.  Someone who actually knows how the internet works, often people who are the basic support for an ISP won't know a whole lot about networking, and just enough to fix 'most' issues.  You want someone who can actually fix the particular issue you are having which could be on the ISP side.
