These cables work with these extensions right?
Go to solution Solved by tristan1035,
Yup, they will work perfectly fine.
Wasn't sure where to post this so went in the PSU because these regards PSU cables... So I wasn't sure, pretty noobish question, your standard PCI-E 6+2 connector from the PSU will work with this silverstone PCI-E extension or it won't?  http://www.newegg.ca/Product/Product.aspx?Item=N82E16812162034&Tpk=Silverstone%20PP07-PCIR%20PCIE
Thank you.
https://linustechtips.com/topic/59574-these-cables-work-with-these-extensions-right/
Yes. They are the standard female ends of the PCIe power connectors. They'll work with any unit you have.
