Im tryin to build a pc for my brothers bday, he wants to play doom and i already got most of the things i need.
an i7 4790 @ 3.6, 1tb WD,16gbs of ddr3 ram, a case, couple fans and a cpu cooler.
And so i was thinking of buying this super cheap mini itx board to go with the upcoming 1070 or 1080
https://www.amazon.com/dp/B00VX1GGWQ/ref=cm_sw_r_cp_api_lBTmxbCA14A87
Will this mobo be able to handle an i7 and a 1080/1070.
https://linustechtips.com/topic/594418-this-should-work-out-fine-right/
Yes.
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
Is this just for gaming? Because an i7 will be overkill. Same with 16GB of memory as well. Also, it is not really the best to go with a B85 chip set. I mean you can, but if you were spending that much on a GPU and CPU you might as well go for a good motherboard to back it all up. Although it would work. Might as well spend a tiny bit more just for precaution.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
16 minutes ago, poopy said:
first its micro atx not mini itx.
what cooler have you got?
when you have got a good cooler i would go with a z97 board so you can overclock. the whole system will last longer if you have the ability do overclock in a couple years.
also what about the psu?
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
I got an evga 850w psu and the i7 is a locked version so i cant OC it, and fpr the cpu cooler i got a corsair h60
oh ups. i thought there was a k. yeah it will work fine. io ports are ok and audio is a at least seperated so nothing weird is going on.
