Hey guys!
First time posting on a forum, but I cant find any info to help me. I recently built a PC with a GTX 980ti and a FX 9590. I noticed that I wasn't getting the fps I was seeing in benchmarks of certain games, and in fact I was getting much worse. In GTA V at 1080p, I was struggling to reach 40 fps and quite often I would dip into single digits. This is the exact same for most other games I play (Rust, Darksouls III, League of Legends, Metro 2033, Tomb Raider 2013, Fallout 4 etc.) all at 1080p with refresh rate of 59Hz. I tried everything I could find including temp checks, usage, overclocking, Nvidia Control Panel settings, driver wipe/reinstall, and even an OS reinstall, but nothing has helped! Even odder, A friend of mine with a 970 and i7 4790k outperforms me in the same games by 30-40 fps at the same resolution and refresh rate. Im not sure what to do, so what gives?
Thanks for your time, everyone!
<>My Specs<>
CPU: AMD FX 9590
CPU Cooler: Corsair H100i GTX
GPU: Gygabite Windforce GTX 980ti
Motherboard: ASUS M5A97 LE R2.0
RAM: Corsair 16Gb DDR3
Storage: WD Black 1 TB
PSU: Raidmaxx 730W
https://linustechtips.com/topic/593740-issues-with-980ti/
5 minutes ago, Realest_Luke said:
Hey guys!
<>My Specs<>
CPU: AMD FX 9590
PSU: Raidmaxx 730W
actually, you motherboard and power supply may be inadequate for an fx 9590, they use a metric ton of power
M1 MacBook Air 256/8 | iPhone 13 pro
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721063
It could be your cpu:
Link from post on Tom's Hardware
http://www.tomshardware.co.uk/answers/id-2714273/amd-9370-intel-core-4590.html
The weakest i5 beats the 9590 in gaming. I would go with Intel.
Battlefield 4 1920x1080 Ultra (FPS Higher is better)
I7-5960X - 110
I7-5930K - 99
I7-5820K - 94
I7-4790K - 94
I5-4690K - 83
FX-9590 - 66
FX-8350 - 62
FX-6300 - 58
FX-6350 - 60
I3-4150 - 50
I5-4460 - 70
Crysis 3 1920x1080 Very High (FPS Higher is better)
I7-5960X - 49
I7-5930K - 48
I7-5820K - 48
I7-4790K - 49
I5-4690K - 46
FX-9590 - 36
FX-8350 - 31
FX-6300 - 30
FX-6350 - 32
I3-4150 - 34
I5-4460 - 41
Far Cry 3 1920x1080 Ultra (FPS Higher is better)
I7-5960X - 73
I7-5930K - 69
I7-5820K - 66
I7-4790K - 80
I5-4690K - 73
FX-9590 - 53
FX-8350 - 51
FX-6300 - 45
FX-6350 - 49
I3-4150 - 52
I5-4460 - 59
CineBENCH R11.5 (Higher is better)
I7-5960X - 14.42
I7-5930K - 11.49
I7-5820K - 10.89
I7-4790K - 9.21
FX-9590 - 7.85
FX-8350 - 6.98
I5-4690K - 6.49
I5-4460 - 5.57
FX-6300 - 4.55
FX-6350 - 5.04
I3-4150 - 3.78
x264 HD Encoding (Higher is better)
I7-5960X - 81.1
I7-5930K - 63.3
I7-5820K - 61.5
I7-4790K - 49.3
FX-9590 - 46.4
FX-8350 - 40.2
I5-4460 - 30.6
I5-4690K - 36.8
FX-6300 - 28.2
FX-6350 - 31.4
I3-4150 - 21.1
Premiere Pro (Time in seconds Lower is better)
I7-5960X - 20
I7-5930K - 23
I7-5820K - 25
I7-4790K - 27
I5-4690K - 37
FX-9590 - 51
FX-8350 - 57
FX-6300 - 89
FX-6350 - 79
I3-4150 - 67
I5-4460 - 44
Power Consumption (Wattage Lower is better)
Idle / Load
I7-5960X - 70 / 306
I7-5930K - 70 / 260
I7-5820K - 70 / 251
I7-4790K - 53 / 236
I5-4690K - 53 / 211
FX-9590 - 94 / 288
FX-8350 - 79 / 249
FX-6300 - 76 / 236
FX-6350 - 75 / 240
I3-4150 - 48 / 196
I5-4460 - 51 / 197
i7 6700k  ·  Asus Z170 - A  · MSI GTX 1080 FE  ·  32gb HyperX 2133  ·  2tb Toshiba 7200 Red  ·   120gb Sandisk SSD  ·   480gb Sandisk SSD  ·  Fractal Design Define S  ·  BenQ XL2730Z 144hz 1440 Freesync
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721065
1 minute ago, RGProductions said:
put your 980ti in your friend's rig and see if it does the same there, if it does you have a bad 980ti
Okay, I'll try that, thanks! If it does the same that means its a bad card like you said, but what if it acts how it should?
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721066
Then look at buying an intel chip :)
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721070
It means your CPU is horrible (which it is, sorry) and you need something better.
I have a good feeling it is your CPU and its bottlenecking your card.
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721074
I7-5960X - 110
I7-5930K - 99
I7-5820K - 94
I7-4790K - 94
I5-4690K - 83
FX-9590 - 66
FX-8350 - 62
FX-6300 - 58
FX-6350 - 60
I3-4150 - 50
I5-4460 - 70
I7-5960X - 49
I7-5930K - 48
I7-5820K - 48
I7-4790K - 49
I5-4690K - 46
FX-9590 - 36
FX-8350 - 31
FX-6300 - 30
FX-6350 - 32
I3-4150 - 34
I5-4460 - 41
I7-5960X - 73
I7-5930K - 69
I7-5820K - 66
I7-4790K - 80
I5-4690K - 73
FX-9590 - 53
FX-8350 - 51
FX-6300 - 45
FX-6350 - 49
I3-4150 - 52
I5-4460 - 59
I7-5960X - 14.42
I7-5930K - 11.49
I7-5820K - 10.89
I7-4790K - 9.21
FX-9590 - 7.85
FX-8350 - 6.98
I5-4690K - 6.49
I5-4460 - 5.57
FX-6300 - 4.55
FX-6350 - 5.04
I3-4150 - 3.78
I7-5960X - 81.1
I7-5930K - 63.3
I7-5820K - 61.5
I7-4790K - 49.3
FX-9590 - 46.4
FX-8350 - 40.2
I5-4460 - 30.6
I5-4690K - 36.8
FX-6300 - 28.2
FX-6350 - 31.4
I3-4150 - 21.1
I7-5960X - 20
I7-5930K - 23
I7-5820K - 25
I7-4790K - 27
I5-4690K - 37
FX-9590 - 51
FX-8350 - 57
FX-6300 - 89
FX-6350 - 79
I3-4150 - 67
I5-4460 - 44
Idle / Load
I7-5960X - 70 / 306
I7-5930K - 70 / 260
I7-5820K - 70 / 251
I7-4790K - 53 / 236
I5-4690K - 53 / 211
FX-9590 - 94 / 288
FX-8350 - 79 / 249
FX-6300 - 76 / 236
FX-6350 - 75 / 240
I3-4150 - 48 / 196
I5-4460 - 51 / 197
Oh wow! Yeah okay, I guess I should look into a cpu/mobo/psu upgrade. Thanks!
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721075
than your fx 9590 is having an issue, you motherboard and power supply are weak plus just get an i5 or something, so much better
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721077
No worries. You won't regret getting an Intel cpu. If you are looking to replace mobo/psu/cpu perhaps a 6600k or 6700k and a nice Z170 mobo. As for Psu with all the new power efficient chips coming out I'm not sure you'd need much more than 750, just grab a gold + with 12v rail :)
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721084
That bottleneck
Magical Pineapples
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721152
On Asus' website, it says your motherboard supports CPUs up to 140W, the 9590 has a tdp of 220W, the motherboard is most likely throttling to save itself. You could potentially get better performance by underclocking/undervolting your cpu, so it doesn't throttle anymore, which is probably the cause of those single digit fps.
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7721166
Awesome man thanks for the help!
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7726620
Ah okay, Im guessing theres online tutorials on how to underclock/undervolt my cpu, thanks!
https://linustechtips.com/topic/593740-issues-with-980ti/#findComment-7726623
