http://de.pcpartpicker.com/p/rLQd8d
Are 850w too much? I will hold off to get the 1080. I want it for gaming, video recording and edit and programming. Also is corsair the right one? And kinda off topic: should i go for a ripjaw ram or is vengeance good?
Ps:if you think i should change anything, inform me
https://linustechtips.com/topic/593664-power/
850W could power nearly three of that system so dial it back a bit unless you plan to SLI. Also, skip the yellow RM as it's old and not that great value. The EVGA GS/GQ/G2 550W are all enough for a 1080 and i7, and 850W is still a tad excessive with two.
https://linustechtips.com/topic/593664-power/#findComment-7721240
