it depends on what type you get
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/59314-do-led-lights-get-hot/#findComment-804669
No, they will remain warm and relatively cool to the touch.
Case = Bitfenix Prodigy, Motherboard = P8Z77 - I Deluxe, CPU = 3570k @ 4.2GHz, RAM = 2x 8GB G-Skill Ripjaws, GPU = Sapphire 7950 Boost Edition, Storage = 256GB Samsung 840 Pro.
https://linustechtips.com/topic/59314-do-led-lights-get-hot/#findComment-804676
Barely, they are low power light emitting diodes. They put out low heat as well as draw low power.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/59314-do-led-lights-get-hot/#findComment-804677
They are so useful because of the fact that they are so cool and use so little power for the amount of light they put out
  • Cooler Master Storm Enforcer
  • I7 3770K @ Stock
  • Gigabyte Z77X-UD5H
  • AMD Radeon R9 290
  • Cooler Master Hyper 212+
  • 16gb Corsair Vengeance 1600mhz
  • 2x 1tb WD Green Drives (RAID 1)
  • 256gb Samsung 840
  • Peripherals
  • Logitech G502 Proteus Core
  • Ducky Shine 3 - Blue LED, Brown Switches
  • Samsung SyncMaster 2443
  • Custom Mousepad http://imgur.com/xJWASQM
  • Logitech G35
  • Altec Lansing Octane 7
https://linustechtips.com/topic/59314-do-led-lights-get-hot/#findComment-804693
LEDs do not get hot. It usually depends on the power emitted by the diodes and their run time. I own the NZXT 2m Sleeved kit and it has never had any temperature issues.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/59314-do-led-lights-get-hot/#findComment-804703
