Hey!
I'm dynamicly creating listboxes in my program and i want to do something with them in another method but it gives me the NullReferenceException exception. What should i do?
       public void newTabButton_Click(object sender, EventArgs e)
            TextBox textBoxJan = new TextBox();
            textBoxJan.KeyDown += new KeyEventHandler(textBoxJan_KeyDown);
            ListBox LBJan = new ListBox();
            tabControl1.TabPages.Add(tabPage);
            tabPage.Controls.Add(LBJan);
            tabPage.Controls.Add(textBoxJan);
    public ListBox LBJan;
    public Label sumLabel;
    public void textBoxJan_KeyDown(object sender, KeyEventArgs e)
        if (e.KeyCode == Keys.Enter)
            if (sender is TextBox)
                TextBox textBoxJan = (TextBox)sender;
                LBJan.Items.Add(textBoxJan.Text)
https://linustechtips.com/topic/592586-c-nullreferenceexception-problem/
You have a public variable of type ListBox, LBJan that you never instantiate and you are attempting to access a property of it in a method (textBoxJan_KeyDown) that will be called multiple times. Your code is a mess.
The single biggest problem in communication is the illusion that it has taken place.
