ARMA 3 Performance problems
Go to solution Solved by jbr,
The Real Virtuality engine is not something you simply throw hardware at and expect to get awesome performance and visuals.
You have to go into the settings and tweak things to get a balance between performance and visuals that you are happy with.
There is an FPS counter in the Video settings, tweak the settings and you'll see the results in real time in that counter.
An important thing to know is that lowering settings is not always what you're supposed to do.
Example:  Shadows are rendered by the CPU when you have them on MEDIUM or LOW and rendered by the GPU when set to HIGH or ULTRA..
HIGH and ULTRA will get you more FPS.
There are several settings that need to be HIGH or ULTRA to switch to the GPU, the more load you offload onto the GPU the better.
You can also lower the resolution and then crank a few things up and still get the great visuals and great FPS.
you do not need to run at your monitors maximum res to get the best visuals.
My monitor can do 1920x1200 but I run Arma 3 at 1680x1050 and have a lot of extra leeway to crank up the visuals and AA because of that
and it looks just the same as running at 1920x1200 on HIGH and ULTRA but without the performance hit.
There's also an issue with WASTELAND which a majority of the complainers bought Arma 3 for.
Wasteland is a poorly coded mission that runs a ton of scripts and really suffers when players and Hackers are dumping tons of objects all over the map
it's also been ported over from Arma 2 and that is also causing problems,  a lot of mods and missions have problems when they are not ported over properly.
Another issue: Servers.
FPS in MP is reliant on the server.
If they server hardware is not up to snuff you will get very bad FPS.
Cheap server hosts also like to throw several games on a single box to save money
so Arma is being forced to share resources with them,....result.... low FPS.
Arma NEEDS a dedicated box that has the required power and bandwidth to run.
Go to the Bohemia forums, there are several years worth of information on how to maximize your performance and visuals.
http://forums.bistudio.com/forumdisplay.php?112-ARMA-3
Arma LOVES SSD'S..... get one.
Hey!
So basically I am getting terrible fps in Arma 3 no matter what settings I choose. I get 17-25 fps on Ultra, 19-28fps on low and It doesnt matter what resolution I play at, 2560x1440 or 1920x1080 (windowed)
My Rig:
i5-3570k (not overclocked atm)
Gigabyte z77x UD3H
Gigabyte GTX 780
8GB Corsair Vengeance 1600MHz RAM
Corsair CX600M power supply
60GB OCZ SSD
2TB WD Green
My flatmate, who is running a GTX 480 and similar components gets better fps, it doesnt drop below 24fps.
Any quick fixes ? Does Nvidia know about the poor performance with the 780 ?
Thanks
https://linustechtips.com/topic/59201-arma-3-performance-problems/
when i run arma i get decent fps (about 40fps) on ultra, but i get huge drops it will drop to about 5fps for a few seconds.
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
Game performance depends on your internet connection. Also Stratis is more optimized than Altis.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
Your performance depends on how good the server is, and you're internet connection. Dont really know why. But if you just want to play with friends, try to make you're own server
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
ARMA 3 FPS fix!
I used to run ArmA 3 at very crap framerates, but now I can play Wasteland with great fps and far rendering distances. This might not work for everyone but it's definitely worth a shot:
1. Go to C:/Users/''yourusername''/My Documents/Arma 3 Alpha and then open the Arma3Alpha.cfg file as a text document.
2. Find GPU_MaxFramesAhead and change it's values to 1; instead of 1000; or whatever it's at.
3. Now change the value of GPU_DetectedFramesAhead to 1; instead of 0;.
4. Launch ArmA 3 and drool at the framerates.
This little fix actually more than doubled my framerate and made the game actually playable for me.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
ARMA 3 FPS fix!
What's the catch?
The game is still unfinished, they haven't been able to optimize it a lot but maybe in a few months we'll see better fps on that game...
the game has been released for over a week now
JBR summed it up very well, you are given full control over your experience with the game. You need to find the balance that you like. Unlike the current gen of console ports, there are no predefined settings for low, medium, high, ultra that work on any PC.
I'd like to add a few minor things.
Definitely overclock your CPU as high as it can possibly go. A lot of the lower than expected fps issues are due to the cpu being the bottleneck. The Arma series is very demanding of CPU's.
An SSD would be a big improvement, due to the size of the game assets, it's somewhat impractical to cache them. So instead Arma relies more on streaming data from the HDD as it's needed. An SSD may not add FPS, but it will run a lot smoother with quicker LOD switching.
Ramdisk is another option which can be used in conjunction with an SSD, although you may want to upgrade your ram or only use a small ramdisk.
Here's a recent thread about ramdisk also contains links to older ramdisk info from arma 2. http://forums.bistudio.com/showthread.php?164641-RAMDisk-size-with-8GB-of-RAM
People have spent many hours tweaking settings in config files (beyond ingame settings) to find the perfect balance for their system. Be prepared to have a love hate relationship with the settings menu. Over time you will find that you switch between several settings based on the type of mission you're playing. Arma is great because it allows such freedom in it's settings.
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
ArmA has way of processing that even the devs don't understand, just take an hour to mess with everything and you'll find the perfect combination.
Hello. Here are some words.
FX-8150, GTX 670, ASRock 990Fx Extreme4, 8Gb Patriot RAM, 1TB boot and Storage, Windows 7 64Bit
http://www.gametracker.com/server_info/85.234.146.76:3062/
Dw, on dayz I get like 40 fps at 1080p in ultra, the games optimization is terrific... Lol
I know, it's completely unfinished still. It should have been in beta for few months still but they promised a release date and that's what they gave you, they released an unfinished game ):
  • 3 years later...
This old thread should definitely be updated there is some misinformation on here, mainly because it's outdated info. Especially the dedicated box thing when a3 servers up until recently only were able to utilize 2 cores and up to but never exceeding 2gb RAM... So there goes the dedicated box theory...As jb stated there are many years of data out there regarding the running of Arma servers and apparently jb didn't read too much of it. And as far as wasteland is concerned there are quite a few different versions of it. And the A3wasteland Code is a work of art so how this guy states it's poorly coded is truly incomprehensible unless he's speaking of someone's hacked together mission. Which can tend to be an issue within the Arma community as a whole no matter what game style you are playing including vanilla ArmA 3 campaign or co-op! The Real Virtuality Engine is probably the most outdated and un-optimized game engine on the market, it's very very inefficient, as I stated before until recently the engine wasn't able to truly utilize over 2 threads of cpu and 2 gb of RAM and now that they finally came of age and produced a 64bit version of the executable they are finally able to try and utilize more. Still many many bugs exist and as always BIS is slow to the take... I mean c'mon it took em over 3 years to add bi-pods for rifles... Just LOOOL!!! Anyhoo this rant is coming from someone whom runs many different game servers (and has for years) three of which are arma 3 and others are valve based games.
