Hello,
I just finished building my first pc and installed windows in it. When i tryed to go on the internet it didnt work. So i checked my lan cable if it was good in my pc and in the router, and it was good. So i looked on the internet and people said i needed to install a new/ the newest drivers for my motherboard, a msi b150 gaming m3. So i did update it. And it still doesnt see my Lan. The lights under the lan cable on my router in port 4 dont blink either. Does any of you guys know how to fix this? Thnx
https://linustechtips.com/topic/591287-lan-not-working/
uh, BIOS is not what you need to install....
you need the LAN drivers from your motherboard website
https://linustechtips.com/topic/591287-lan-not-working/#findComment-7695140
21 minutes ago, Thx And Bye said:
Are you 100% sure its a problem of your mainboard and not the router?
Did you try a different cable?
Yes, ive checked the canble if it was good connect. I also tryed another cable. Didnt work either. And i tryed other lan ports on my router
https://linustechtips.com/topic/591287-lan-not-working/#findComment-7695306
checked with another computer at the other end?
https://linustechtips.com/topic/591287-lan-not-working/#findComment-7695473
