2 minutes ago, DanielB126 said:
Basically just looking for a Full tower silent case, budget is around £100 or so.
My main priority is for it to be made to be quiet.
Define R5
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/590917-quiet-full-tower-case/#findComment-7690668
4 minutes ago, TheGhzGuy said:
Define R5
R5 is an American pop rock band formed in Los Angeles, California, in 2009. The band consists of vocalist/rhythm guitarist Ross Lynch, Riker Lynch, (bass/vocals) Rocky Lynch (lead guitar/vocals), Rydel Lynch (keyboard/vocals), and Ellington Ratliff (drums/vocals).
Tip to those that are new on LTT forum- quote a post so that the person you are quoting gets a notification, otherwise they'll have no idea that you did. You can also use a tag such as @Ryoutarou97 (replace my username with anyone's. You should get a dropdown after you type the "@")to send a notification, but quoting is preferable.
Feel free to PM me about absolutely anything be it tech, math, literature, etc. I'll try my best to help. I'm currently looking for a cheap used build for around $25 to set up as a home server if anyone is selling.
If you are a native speaker please use proper English if you can. Punctuation, capitalization, and spelling are as important to making your message readable as proper night theme formatting is.
My build is fully operational, but won't be posted until after I get a GPU in it and the case arted up.
https://linustechtips.com/topic/590917-quiet-full-tower-case/#findComment-7690686
haha
https://linustechtips.com/topic/590917-quiet-full-tower-case/#findComment-7690699
Cases are inherently silent. Use quiet components and you will have a quiet system.
BeQuiet!'s cases are the only ones that come with good fans imo that are very quiet. If you're not going with one of their cases, get aftermarket fans.
https://linustechtips.com/topic/590917-quiet-full-tower-case/#findComment-7695987
