So I wasted a lot of time looking through amazon and other sites for a pci-e 16x riser cable for modding my pc to place my graphics card sideways to display it through the window, so its NOT for mining.
Now I could not find an item, since the reviews either say its burned and shorted out, or they say it work fine. And they weren't enough reviews to begin with.
All I could find is 3M one that is 50cm or 25cm which are too long for my use, not to mention too expensive. So I just want a working one that don't suffer from unexpected crashes and performance drop.
I did however find these 2, but not sure if they would be the same as the crappy ones from amazon.
these two:
http://www.moddiy.com/products/PCI%252dExpress-PCI%252dE-Extension-Cable-Riser-%2819cm%29.html
and
http://www.moddiy.com/products/Premium-Gold-Plated-16x-PCI%252dE-Extension-Shielded-Cable-Riser-%2819cm%29.html
My plan is to install the GPU just like the picture below
https://linustechtips.com/topic/590852-choosing-a-pci-e-riser-cable/
6 minutes ago, KnightWumar said:
did the same thing with my build:
if the room temperature goes under 15°C my pc doesnt post.
otherwise its brilliant :D
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
4 hours ago, KnightWumar said:
-SNIP-
Your best bet with those two is the shielded one, it's hard to say for the cheap unshielded cables as they are usually a luck of the draw for it it will work effectively. Lian-li makes a pretty good ones also:
http://www.lian-li.com/en/dt_portfolio/pw-pci-e/
ChrisCross, really nice build. But what is the exact extension cable that you used ? Did you notice and crashed or performance issues ? And why does it not post when the
temperature is low ?
And DAMN that one is too damn expensive. And its too long, I need about 15-19 cm cable.
For ones that are that short the the shielded ones do work as it's not as long, but like usual not always a guarantee.
