Fan speed
Go to solution Solved by Andrew48,
You will put too much stress on the resistor used in low noise adapters and you will probably burn them. Use one low noise adapter per fan or get a fan controller
Why don't you just reduce the speed through the bios?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/59033-fan-speed/#findComment-800661
Maybe he has a z77a G45 like me that has terrible onboard fan control.
https://linustechtips.com/topic/59033-fan-speed/#findComment-804993
Yes, but that could mean some fans wont run at all. For two fans its ok, but more could mean that fans don't get enough power. Someone with more electrical experience will have to confirm this. But why not test it if you have splitter and reducers already. Connect them to PSU and have fun.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/59033-fan-speed/#findComment-805163
AMD FX 8320@ Stock - Asus M5A99X Evo R2.0 - Kingston HyperX 8GB 1600Mhz - Corsair Carbide 200R - Powercolor Radeon HD 7950 PCS+OC@970Mhz core 1400Mhz memory - Corsair CS650W - Samsung 840 EVO 250GB
LG 22EA53VQ 21.5" - CM Storm Xornet - CM Storm Quickfire TK - Creative Inspire T3130 2.1
https://linustechtips.com/topic/59033-fan-speed/#findComment-805259
