So I'm thinking about water cooling my PC, but the problem is, there isn't much space in my case.
I'm using NZXT S340 case and it can only fir 240/280mm radiator.
I have i7 4790 CPU (not K edition sadly, but since I can't overclock it, it shouldn't generate too much heat) + R9 390 nitro with backplate.
I will have to order GPU waterblock from Alphacool, because EKWB doesn't make those sadly.
But will be 240/280mm radiator enough to cool down both CPU and GPU in my system? I had in mind this rad: http://www.alphacool.com/shop/radiatoren/radiatoren-aktiv/15932/alphacool-nexxxos-st30-full-copper-280mm?c=20544
Someone once told me that one 120/140 is for each component + 1 additional. But I can't fit 360mm rad into my case.
But what about 280mm rad + 120 rad on the back of the case?
So I would have 280mm rad in front + 120mm at the back. Would that improve temperatures and would that even work? I also plan to use only 1 pump and 1 Reservoir.
If anyone have some suggestions about my idea, please let me know :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/590275-240280-rad-for-cpu-gpu/
From what I know about watercooling (that is emdium/low knowledge) this sounds fine though I would try to get a Rad with higher FPI.
have you read this one?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/590275-240280-rad-for-cpu-gpu/#findComment-7683082
Totally fine. I have a 240mm rad for my CPU and GPU, my gpu is a 7970 OC'd to the max it can go. CPU is at 4.0ghz, and my temps dont go above 50 under benchmarks. If you can fit a thicker rad then go for it. Also, I've a good experience with alphacool.
Tohrchur
https://linustechtips.com/topic/590275-240280-rad-for-cpu-gpu/#findComment-7683956
It will be sufficient, but also keep in mind you could add a couple more 120mm radiators to the loop if you wanted or are worried that a single 240 won't be enough.
my work in progress
i5 6600k  //  16gb g.skill ddr4 3000  //  evga gtx 980
custom water loop
https://linustechtips.com/topic/590275-240280-rad-for-cpu-gpu/#findComment-7684944
I guess I will just buy single 280 rad for now and benchmark it.
If resaults will be bad, I will just buy another 120mm rad and put it somewhere in case. After buying full loop, that another rad won't be such a problem since it cost like 50€ or somewhere around that :)
Thanks everyone for answers :)
WD My Cloud 4TB
https://linustechtips.com/topic/590275-240280-rad-for-cpu-gpu/#findComment-7685287
