Z170-A PRO front audio
Go to solution Solved by STRMfrmXMN,
13 minutes ago, Chris Yahya said:
well previous mobo (H61M-S2P-B3 Gigabyte) the audio is working. but thats a 2 month ago before i buy msi.
can it mobo defect or cable defect?
i'll check the cables are they damaged or not.
if damaged, how to repair it?
It can be either.
Good idea.
Soldering if it's the cable, RMA the motherboard if it's the motherboard.
2 minutes ago, Chris Yahya said:
hello, i have Z170A PRO , using Corsair Carbide SPEC 01, which it has "HD AUDIO" plug.
i plugged it in to the mobo, but none audio detected when i plug audio jack in front audio.
help!
rear audio jack is working properly.
Sure the pins are all lined up? Possibly defective cable.
https://linustechtips.com/topic/590192-z170-a-pro-front-audio/#findComment-7682069
a GeForce GTX series 970 user.
https://linustechtips.com/topic/590192-z170-a-pro-front-audio/#findComment-7682138
It can be either.
Good idea.
https://linustechtips.com/topic/590192-z170-a-pro-front-audio/#findComment-7682188
On 5/2/2016 at 11:40 AM, STRMfrmXMN said:
It can be either.
Good idea.
now the difficult thing is : i only have cheapo Case which it has Audio jack but i'm very sure they're not HD audio, or maybe AC 97....
https://linustechtips.com/topic/590192-z170-a-pro-front-audio/#findComment-7688387
If so, check the BIOS. On older boards there was an option to chose between AC97 or HD audio. If yours has this too, this should fix it. The cable/connector is the same.
https://linustechtips.com/topic/590192-z170-a-pro-front-audio/#findComment-7688580
