So i hate weird problems..
So i overclocked my GPU..+85 Core Clock.
In GTA V works fine, but in rainbow six siege i get a crash in 15 minutes of gameplay. I change core clock to +75 rainbow six siege works fine but in GTA fps won't go above 30...
so wtf is going on?
https://linustechtips.com/topic/589983-weird-problems/
You shouldn't need to overclock your card to get 60 FPS, just lower your game settings a bit.'
If it crashes.. then it's not stable.
(Assuming you're at 1080p and not like 4k or something. And also assuming that the system you are referring to is the one on your profile)
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/589983-weird-problems/#findComment-7679876
Reinstall drivers maybe?
Also, have you tried +80? as 85 makes your R6S crash while 75 causes problems in GTAV...
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/589983-weird-problems/#findComment-7679962
i'm at 1440p
https://linustechtips.com/topic/589983-weird-problems/#findComment-7680025
i have no idea..
I did reinstall drivers but GTA loves +85 and R6S hates it.. if i move to +75 then R6S will works fine but GTA will crash.. so yeah..
https://linustechtips.com/topic/589983-weird-problems/#findComment-7680034
Just now, lovingGamer said:
i have no idea..
Stock speeds?
https://linustechtips.com/topic/589983-weird-problems/#findComment-7680035
what the hell are you talking about.. do you see that i have added +85 or +75.. that means OC.. and when it runs stock it's fine..
Then there's something wrong with your OC...simple as that...if it's not running stable with your OC but runs stable at stock then you're doing something wrong or the card isn't able to handle those clocks.
https://linustechtips.com/topic/589983-weird-problems/#findComment-7680079
but but but.... FUCK!
So GTA V runs fine on +85 Core clock
but R6S crashes on +60 Core clock
and GTA V crashes on +60
so that means GTA V runs better at hire clock speed.. weird as fuck
https://linustechtips.com/topic/589983-weird-problems/#findComment-7683357
