Low FPS in Witcher 3
Go to solution Solved by Moonzy,
1 minute ago, dappy10 said:
yea version 364.72, sorry but how do i do a driver rollback?
uninstall it using Display Driver Uninstaller, then download an older driver from nvidia for the OS you're using (i recommend the 361.91 since im using it) and install it
For some reason, I've been getting low fps on witcher 3 recently. This hasn't happened before. I don't remember doing anything to the computer besides OC'ing my gpu, which after setting it back still didn't change anything.
I set the graphic settings to low and I got 30 FPS when a week ago I would've easily been getting 80, I noticed a difference that my cpu usages are lower compared to then, my cpu usages would hover around 90% but right now it's around 50%. I tried updating drivers via driver booster. I also noticed that playing witcher on low would be smooth, while on high would be laggy but there was little to no change in fps
CPU: A8 7650K (not oc'd)
GPU: GTX 960
MOBO: A68HM-PLUS
https://linustechtips.com/topic/589731-low-fps-in-witcher-3/
Are your power options set to high performance mode?  it might make a difference, I've been amazed by the difference it makes.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/589731-low-fps-in-witcher-3/#findComment-7677491
1 minute ago, Moonzy said:
what version are you running on?
if its the 364.xx gpu driver then try rolling it back to something older like 361.xx or 362.xx, 361.91 for example
see if this fixes the issue
https://linustechtips.com/topic/589731-low-fps-in-witcher-3/#findComment-7677498
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/589731-low-fps-in-witcher-3/#findComment-7677504
Thanks! My fps is much better now, I guess it was an NVidia driver.
Although my drivers are crashing and restoring, ill take that for better fps
Cheers
(preset on high)
https://linustechtips.com/topic/589731-low-fps-in-witcher-3/#findComment-7677576
