So i'd like to overclock my 4790k
I have a corsair H100I V2 as the cooler and a MSI H81M-E33 motherboard and whenever I try to overclock past 4.0 GHZ or 40 multiplayer of 100 mhz it just doesn't budge and I know it can take I have the watercooling with a 240MM RAD so it can overclock. So any help?
Build Name:
Anton
CPU: I7 4790K
GPU: ZOTAC RTX 2060 SUPER AMP EXTREME
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
CASE: COOLER MASTER N300
PSU: THERMALTAKE 600 WATT
STORAGE: TOTAL 6.5TB, 512GB SAMSUNG 850 PRO BOOT DRIVE, 2TB HDD 1, 2TB HDD 2, 2TB WESTERN DIGITAL USB 3.0 BACKUP DRIVE
- CRACK!
https://linustechtips.com/topic/589288-4790k-overclocking-issues/
you need a motherboard that supports overclocking
Just now, Moonzy said:
you need z87 or z97 motherboard to overclock
Aw man dang such a disappointment not even anything such as some program or whatever can do it well I now know what to save up for
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
no way to overclock other than getting an overclocking supported motherboard
-sigh- feeling like I'm being too negative lately
well ok but there is still positivism having the CPU being watercooled and be low profile in thermals means I can overclock GPU more to comphensate
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
cpu temps have nothing to do with gpu overclocking lol
Yeah I know I'm talking about like case and computer overall having a watercooler isolate heat away from case productively means I can make GPU pump more heat without as more ramifications
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
