1 hour ago, KooKooMan117 said:
Would my build bottleneck a gtx 950?
No, but once you go above say a GTX 770 or 760 then it will bottleneck
I would suggest upgrading your CPU as BF4 is very CPU intensive. Plus BF5 is right around the corner with its announcement 6 days away so keep that in mind
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/589224-a-card-for-bf4/#findComment-7674068
A bit yes. Go for a 750 Ti
https://linustechtips.com/topic/589224-a-card-for-bf4/#findComment-7674116
