Help me pick an AIO water cooler
21 minutes ago, LordDre said:Any feedback is fine, but i wanted to here someone with water cooling system. Thanks:) I will check them out!
There are so many opinions about air vs water. It boils down to what type of cooling you prefer and it sounds like you prefer water.
AIO water coolers are fantastic. Contrary to some of the opinions in this thread, pump noise is minimal or nonexistent provided that the system is functioning correctly. I personally no longer use AIOs as I have moved onto larger custom loops in order to remain silent at very high CPU and GPU overclocks, but I can tell you that I'd use a quality AIO water cooler without hesitation.
With water cooling, whether it be AIO or custom loop, the more radiator surface area used to displace heat, the slower (quieter) your fans can run. With that said, I looked up the specs on your case and you have a couple of options. My recommendation would be to go with the largest AIO that you are comfortable spending money on. The 240mm would be ideal as it would allow for better heat displacement at a lower fan speed. Effectively, you'd have the same cooling capacity without all of the noise and if you chose, you can turn up the fans resulting in even more cooling capacity.
Always buy a larger radiator than you think you need. The old 120mm per water block rule is for the absolute bare minimum cooling. 240mm per block and higher is much better.
Something like this H100i-v2 would work well for you.
http://www.corsair.com/en-us/hydro-series-h100i-v2-extreme-performance-liquid-cpu-cooler
Good luck!
