3 minutes ago, Elishah98 said:
going to buy this soon but just need confirmation, are these parts compatible? I'm not real sure if pcpartpicker is right when they say they are compatible. http://pcpartpicker.com/p/KPcrJx and if you see any changes I could make let me know please, thanks!
Do you need cuda? OR does power cost alot where you live?
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661431
1 minute ago, Starelementpoke said:
Then you probably won't need it. Get the 390 instead.
savage
@Elishah98, you can double your SSD storage space if you can fork out a couple more bucks, 120gb ssd dont have a good value
also, im assuming you already have a case? what case is it? as compatibility mostly have to do with your case
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661470
You should be getting an i7 6700 and a 390, both will be better choices and the 390 is going to be faster than a 970 and give you solid gains in DX12
PCPartPicker part list: http://pcpartpicker.com/p/XJ2LVn
Price breakdown by merchant: http://pcpartpicker.com/p/XJ2LVn/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($301.99 @ SuperBiiz)
Motherboard: MSI B150M Pro-VD Micro ATX LGA1151 Motherboard  ($59.99 @ Micro Center)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($54.00 @ Newegg)
Storage: Mushkin ECO3 240GB 2.5" Solid State Drive  ($59.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ Micro Center)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($308.99 @ SuperBiiz)
Case: Cooler Master N400 ATX Mid Tower Case  ($55.99 @ SuperBiiz)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $958.93
Generated by PCPartPicker 2016-04-27 16:41 EDT-0400
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661475
2 minutes ago, Moonzy said:
savage
Definitely going to double my ssd thanks for mentioning that, also this is the case I'm mostly likely getting http://www.thermaltakeusa.com/mobile/productinfo.aspx?id=C_00002473
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661493
Total: $958.93
Always liked nvidia and never checked out Radeon but will definitely look up some stuff and most likely will go with it, any reason for such a cheap motherboard? I've seen so many people go with expensive cpu and gpu and cheap motherboard
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661502
Because the motherboard doesn't effect the performance, only the features you get. Unless you need a bazillion sata ports, usually not worth.
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661511
might have to remove a hard drive cage or two to fit the gpu in
other than that, should be no problem
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661514
You just need to pick the right budget board, pretty much all the MSI ones offer USB 3.1 and great power delivery, the higher end boards mostly just offer more PCI-e lanes which most people don't need, or maybe like display port onboard, which again most people won't use
390 vs 970 benchmarks, more so wins at 1440p though, but you still save money should you get like a 1080p 144hz free-sync display, G-sync ones cost $100 more minimum, and then there's all the DX12 stuff
390 benchmarks
http://www.tomshardware.com/reviews/sapphire-nitro-r9-390-8g-d5,4245.html
http://www.eurogamer.net/articles/digitalfoundry-2015-amd-radeon-r9-390-8gb-review
Dunno why the videos didn't embed
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661528
https://www.youtube.com/watch?v=55sEPM7Ux-U380
390 benchmarks
https://www.youtube.com/watch?v=k9cKZiJw6Pk
https://www.youtube.com/watch?v=udXCusTnRsY
Thanks man for the links, will definitely check them out, I'm planning on having a double monitor setup, would the r9 be good for that?
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661587
Really? They have a picture of a gtx in it and doesn't look like they removed anything but idk
well, depends on which card you get
since you're still debating with the others
tbh i also support the choice of going with the r9 390 for more gaming performance
but if you like nvidia better then gtx 970 is fine too, they come with more features anyway
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661598
Anything can run multiple monitors, need to start worrying about the GPU when you try to run more than 6
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661625
More features?
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661626
1 minute ago, Elishah98 said:
More features?
geforce experience, shadowplay, gamestream co-op, nvidia shield, and a couple more small features
but its pointless to have them if you dont use them lol
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661635
CUDA support and ShadowPlay, the latter of which can be supplanted with OBS and Quicksync.
they're not as elegant as shadowplay, and the performance hit is bigger too
so i wouldnt say that they can replace shadowplay entirely tbh lol
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661648
More features?
AMD has a shadowplay thing called GDVR, dunno about the rest of that though, I don't know of anyone who owns/uses a shield though....
but ya with an i7 6700 you have OBS which is going to give you more control and higher quality footage than shadowplay/GDVR, those things are more for weaker systems I'd say. But finding recent comparisons is hard.
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661649
i5 6600K should have much better single core performance than the 6700, assuming you overclock it of course
so it will perform better in some cpu bound games like arma 3 or some not so well optimized mmos
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661657
Not when you start streaming though, and the 6700 already turbos pretty high, even with an OC at most you're probably going to end up at like 4.5ghz which isn't really going to be worth it over losing hyperthreading.
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661843
thats why shadowplay exist...
but yea, i7 vs i5, it depends on what the OP wants to do
if he wanna stream professionally, the i7 would do him better
if he just wanna record some gameplays from time to time, the i5 will serve him better
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661877
Probably going to go with the i7, I want to stream for sure and record game plays from time to time also. So i7 is probably best for me
https://linustechtips.com/topic/588249-compatible-build/#findComment-7661949
