Troubleshooting my stupidity on using CCleaner
On 4/25/2016 at 7:54 PM, LAwLz said:Here is how to use a Ubuntu LiveCD:
1) Download Ubuntu.
You can download it, for free (legally) by following this link.
2) Download Rufus.
You will need this program to transfer the Ubuntu ISO file to a USB memory stick and make it bootable. Here is the link to Rufus.
3) Plug in an EMPTY USB memory stick.
Make sure you DO NOT HAVE ANYTHING IMPORTANT ON IT. Everything on it WILL BE DELETED. So make sure you do not have any important files on it.
4) Create the bootable USB memory stick.
You do this by opening Rufus, chance so that everything matches the settings you see in the image, then press the little disc icon and select the Ubuntu ISO you just downloaded.
Make sure that the thing under "device" is the empty USB memory stick you just plugged in. In my case it was a 16GB memory stick called "YAMI". Yours will probably be different.
When you're done click start. It might happen that these two windows appear.
Just click "Yes" on the first one about "Download required". On the second one select "Write in ISO Image mode (Recommended)" and press OK.
A third popup will appear saying that everything on the device you selected will be deleted. So again, make sure you do not have anything important on the USB memory stick and make sure you selected the correct device. This is one of the two "dangerous" steps. As long as you do not have any other USB memory stick, external hard drive or similar device plugged in you will be fine. If you have multiple plugged in then you must check and double check to see if you have selected the correct one.
5) Reboot your computer with the USB memory stick still plugged in.
This step will different depending on which motherboard you got. What you want to do is boot from the USB memory stick. It's often accessed with esc or F12. Once you have accessed the boot menu you want to select the USB storage device (or something along those lines).
6) Boot into Ubuntu Live CD mode.
You will be greeted with a language select screen if everything went well. Just select English and press enter. Once that's done you will see this screen. This is the second thing where you can screw up. You want to select "Try Ubuntu without installing". You do not want to press anything else. It's not really dangerous to press anything else, but if you select Install ubuntu and then go through the entire process you might end up deleting everything. Don't worry though, there are plenty of "are you sure you want to do this" popups that will stop you from doing it accidentally.
As you can see in this screenshot, "Try Ubuntu without installing" is the first option and it is already selected, so just press enter.
7) Find that file and save it.
The easiest way of finding it will be to open the file manager.
Just find the files you want to save and then copy them over to another USB memory stick (the LiveCD is read only, so anything you put on that USB memory stick will be deleted).
Thank you very much for helping me with this. Apparently I went with an IT guy and he recommended the same thing here, so I did it and used an empty usb as a LiveCD and got my files back. Now my system is restoring and will be fine after all the updates. Thank you very much good sir!
