FRAPS Issues
Really? Nobody knows whats going on here and you just start screaming for him to use something else? The choppy playback is quite normal, it's because of the massive amount of data that is being read and the system can't keep up. It's not a problem, since the file is WAY to big to keep anyway you just need to re-encode it to something else. If you encode it with x264 at something like 11 000 to 15 000 bitrate. You'll shrink it down and you get WAY better quality then when you would have recorded it with OBS or shadowplay. That's because OBS uses settings to make the encoding go as fast as possible, sacrificing quality.
I record with fraps all the time and do the same thing. Yes it takes more time but the result (at least for me) is better then other solutions.
edit: Fraps is however outdated for resolutions above 1080p. 1440 is doable but the framerate drops by a lot more. 4K recording with fraps is IMPOSSIBLE. the program can't handle it and all performance just tanks. Doesn't matter if you write to an HDD or a PCI-E SSD, and i've tried both. OBS crashes as well when recording 4k, so that doesn't work either...
