Onboard graphics won't work
Solved by Guest,
In the case that the integrated graphics did break, shouldn't it cause the mobo to malfunction?
I don't think its the connectors because i tried vga, dvi and the hdmi output...
I think a single component on a motherboard can malfunction without the whole thing going down (if it's not essential to running the pc, of course)
Only suggestion I have left is to try replacing the motherboard ![]()
Why do you even want to run without your discrete GPU?
