NFC is extremely slow and does very little data transferring.
On phones, the NFC transfer is just enough data to tell the two phones to open a bluetooth connection and send/receive the file. You'd be just as fast and doing the same thing just sending it to your computer by bluetooth.
If you really want to do it by NFC I am not aware of any one thing you can buy, it will take a scanner, microcrontroller, bluetooth dongle, and you'll have to write a program to take care of everything in the background on your computer.
https://linustechtips.com/topic/586394-nfc-technology-desk-help/#findComment-7644952
You are better off with BT or WLAN. NFC tops out at about 1 Mbit/s what is way to low for decent file transfer.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/586394-nfc-technology-desk-help/#findComment-7645012
