are you looking for a really high OC? if so, go for something like a dual 120mm radiator AIO, if not, something like a 212 is a great option above a stock cooler that is cheap and performs great.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/585958-cpu-and-cooling/#findComment-7637576
Would you recommend the 212 or the D92?
https://linustechtips.com/topic/585958-cpu-and-cooling/#findComment-7637584
I don't think there would be any massive difference in performance between the two, although the D92 is more aesthetic, so if thats worth the extra $10 to you, go for it.
https://linustechtips.com/topic/585958-cpu-and-cooling/#findComment-7637587
Popular choice would be the Cooler Master Hyper 212 EVO but there are other choices that edge it out in terms of cooling while being more aesthetically pleasing. So with that said, I'd say to get either the Cryorig H7 or the beQuiet! Pure Rock.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/585958-cpu-and-cooling/#findComment-7637592
Ok, one last question. My current CPU cooler is a liquid cooling one that I've had for a while now. I couldn't tell you what kind it is, but I got it from iBuypower. Do you think I even need a new cooler?
https://linustechtips.com/topic/585958-cpu-and-cooling/#findComment-7637593
its probably a single rad cooler, my friend has had one, in which case the only worthwile upgrade would be to a dual rad AIO, but again, its not very useful (even the one you have) if you aren't going to be overclocking (which I definitely recommend on your AMD CPU).
https://linustechtips.com/topic/585958-cpu-and-cooling/#findComment-7637597
Decent air cooler on a reasonable budget - Cryorig H7
Not arsed about cost, but still cheaper than a dual fan radiator - Noctua NH-D15
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/585958-cpu-and-cooling/#findComment-7637617
