quality
usually more money=better
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
1 minute ago, Legolessed said:
So I was looking at buying a 400w psu on Amazon and I found that the prices varied widely. A brand I have never heard of before is selling one for $8, EVGA is selling one for $19.99, and corsair is selling one for $43. What's the difference?
The quality of the unit.
What is the system you're powering?
Just now, thekeemo said:
1. warranty
2. wattage
3. quality of components
4. cables
5. soldering
2 minutes ago, Moonzy said:
the difference is how good they are
at starting fire
3 minutes ago, shadowbyte said:
quality
This is the system I'm powering. http://pcpartpicker.com/p/thQRpg
What are the 3 models of PSU were you looking at?
Differences between brands:
Some are good, others bad.  If you want to play it safe, Seasonic is easily the best of all makers available, plus their prices have been progressively exploring lower grounds! (comparable to Delta???)
Diablotek is bad.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
15 minutes ago, Legolessed said:
Both of those aren't the greatest PSU EVGA and Corsair lower end stuff isn't that great compared to the EVGA G2 or Corsair HXI. But as you aren't powering a high end build go with either of those.
ok. EVGA is the only company that i know of that has a psu for that cheap. Are there any other power supplies that are still very cheap but are higher quality?
Diablotek is bad.
at starting fire
1 hour ago, shadowbyte said:
quality
which is better? http://www.amazon.com/dp/B004JUVNVC/?tag=pcpapi- http://www.amazon.com/EVGA-Continuous-Warranty-Supply-100-N1-0400-L1/dp/B00LV8TZAG/ref=sr_1_1?s=pc&ie=UTF8&qid=1461304317&sr=1-1&keywords=EVGA+400w
It seems that the general consensus in some places on the internet, is there are not many decent power supplies in the 400w range. Unless you want to drop $100 on a Be Quiet modular unit, but even that's 550w.
JohnnyGURU is a fairly well respected reviewer, and the EVGA 430w unit seemed to do well enough in his tests. No, it's not the greatest power supply in the world, and it's about double what you are looking to spend. However, it's going to be vastly superior to a $20 new unit from anyone, even the $20 unit from EVGA that's not made to the same standards.
http://www.amazon.com/EVGA-Continuous-Warranty-Supply-100-W1-0430-KR/dp/B00H33SDR4/ref=sr_1_1?ie=UTF8&qid=1461305582&sr=8-1&keywords=evga+430w
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
